General Robotics
M0601 Motor – Maximum Input Voltage and 5S LiPo Battery Compatibility
userHead alexgautier 2026-10-09 16:57:32 499 Views1 Replies
What is the minimum and maximum operating voltage of the M0601 motor;
Thank you!
2026-10-10 09:24:55
M0601 (AGV direct-drive hub motor), the official specification states a 18V DC rated voltage.
It is not recommended to use this battery. Either add a step-down circuit to stabilize it at around 18V, and this should work.
userHeadPic Jason.Miao
