Huskylens I2C to Maqueen Plus
Bravia 2026-10-25 04:40:52 795 Views5 Replies Cannot connect Huskylens V2 to Maqueen Plus on I2C
cable connections
does “ T ’ on Huskylens Connect to SDA on Maqueen Plus
& “ R “ on Huskylens connect to SCL on Maqueen Plus
Your wiring is actually correct — in I2C mode the HuskyLens pins are T = SDA and R = SCL, so T→SDA / R→SCL on the Maqueen Plus is right. So the problem is elsewhere; check these:
Power. HuskyLens 2 needs 5V and draws a lot of current. Use the 5V I2C port on the Maqueen Plus, not the 3.3V I2C ports, and if it still won't come up, power HuskyLens from its own USB-C (the official micro:bit guide does exactly that — it powers HuskyLens separately). A sagging rail is the most common reason for "no I2C connection".Protocol + address. HUSKYLENS 2 ships in I2C mode (address 0x50; the older V1 was 0x32). The indicator at the UART/I2C port glows blue in I2C, green in UART — make sure it's blue.Extension/library. Use the HUSKYLENS 2 blocks/library, not a V1-only one: in MakeCode search the extension "huskylensv2"; on Arduino it's DFRobot_HuskylensV2.Follow the official Maqueen path. The Maqueen Plus wiki has an "Install HuskyLens Camera for Maqueen V2.0" section, and the advanced tutorial connects HUSKYLENS to the I2C port — matching that wiring photo is the quickest fix.Also check the 4-pin cable orientation against the port silkscreen (VCC/GND/SDA/SCL) so power isn't reversed.
Jason.Miao These materials might be useful to you.
HuskyLens pinout (T=SDA, R=SCL): https://wiki.dfrobot.com/sen0305HUSKYLENS 2 protocol/address (0x50, blue=I2C): https://wiki.dfrobot.com/sen0638/docs/22600HUSKYLENS 2 micro:bit wiring + extra power: https://wiki.dfrobot.com/sen0638/docs/24853Maqueen Plus wiki (HuskyLens install section): https://wiki.dfrobot.com/mbt0021-en/Maqueen Plus + HUSKYLENS tutorial: https://learn.dfrobot.com/makelog-308558.htmlLibrary: https://github.com/DFRobot/DFRobot_HuskylensV2Thanks Jason for Reply.that the connection sorted.
Can you direct me pls to sample code for Huskylens & Maqueen plus\Microbit as Df Robot doesnt have Maqueen Plus as an Extension on list.
There don't seem to be any official examples for these two, but that doesn't mean they can't be connected. There are some common embedded techniques. When connecting the two modules, the first thing to do is to check if they have a common communication method. The second is to look at how the code is written (you can directly use AI. After sending the data of the Macken car and the HUSKYLENS 2 to the AI, let it generate the code for connecting the two modules for you. Even all the possible codes are possible).
Make sure to clearly communicate your hardware configuration and the software you are using to the AI. You can also have the AI ask you questions to better understand your requirements. This will increase the success rate.
