Custom carrier board USBC video capabilities
userHead Warwick.Freeman 2026-10-29 17:51:33 772 Views3 Replies
I am designing a custom carrier board for the lattepanda Mu module.  I want the board to have a USBC port that carried the display capabilities.  I note that the Mini carrier board has sample circuits for this function.  One thing is the IT8851 device.  Does anyone know which variant of this part is used and what firmware needs to be loaded.  Are the parts available pre programmed or do we need to program them with firmware compatible with the Mu module.
2026-10-30 18:47:54
Thanks Jason.  That is why i asked the question.  The documentation indicates that the bios and the IT851FN firmware interact together so without the firmware for the IT851 I dont think it can work.  I am trying to find out if Ican get the devices and if so where I can source the firmware if its not pre-programmed.
userHeadPic Warwick.Freeman
Jason.Miao wrote:
You should ask their technical support team to see if they can provide it to you. Clearly state your requirements and request their technical support.
2026-11-02 09:00:28
2026-10-30 09:58:27
LattePanda-Mu/Electricals/Examples/[DFR1293]Mini Carrier for LattePanda Mu and Mu Ultra/DFR1293 Mini Carrier Board Schematic.pdf at main · LattePandaTeam/LattePanda-Mu · GitHub
The schematic diagram is open-source, but the firmware is not included. This might have been pre-installed at the factory.
ITE lists IT8851FN with a built-in 8051 MCU and 64 KB flash, and no external flash support. So the PD firmware sits in the chip's internal flash and must be programmed — it's not in DFRobot's open package
Developing your own carrier board is prone to mistakes. Make sure to gather all the necessary materials before you start.
userHeadPic Jason.Miao
