SEN0630 IMX219 Camera – Pin 6 GPIO, 22-pin FFC Pinout and MIPI CSI-2 Specifications
Kato 2026-10-31 07:54:27 215 Views2 Replies Hello DFRobot Technical Support Team,
I purchased the DFRobot SEN0630 (IMX219-77-4Lane 8MP Camera for Raspberry Pi 5) from DigiKey.
I would like to connect this camera to an Altera Agilex 3 FPGA development board using a 22-pin, 0.5 mm pitch FFC cable and a MIPI CSI-2 interface.
Before powering on the camera, I would appreciate clarification of the following technical details.
1. Pin 6 (GPIO) function
What is the exact function of pin 6 on the SEN0630 22-pin connector?
Is it connected to PWDN, RESET, a voltage regulator enable input, or another circuit?
Is the signal active-high or active-low?
Does pin 6 require a pull-up or pull-down resistor during power-up?
What is the permitted voltage range for this signal?
2. 22-pin FFC cable and connector
Does the supplied FFC cable connect pin 1 to pin 1, pin 2 to pin 2, and so on?
Is the cable a same-side-contact or opposite-side-contact type?
Could you provide the part numbers of the FFC cable and the camera-side connector?
Could you confirm the physical location of pin 1 on the SEN0630 PCB?
3. MIPI CSI-2 and clock specifications
Does SEN0630 support 2-lane MIPI CSI-2 operation, in addition to 4-lane operation?
What is the sensor's external input clock frequency (INCK/XCLK)? Is it 24 MHz?
What is the supported MIPI data rate per lane?
Is the standard Raspberry Pi IMX219 register initialization sequence suitable for this module?
4. Power specifications
What is the expected current consumption from the 3.3 V supply?
Are there any special power sequencing requirements?
If available, could you please share the SEN0630 schematic, connector pinout drawing, or relevant hardware documentation?
I am keeping the camera powered off until the electrical connections and power requirements are confirmed.
Thank you very much for your technical assistance.
This is their official information. It might be able to help you.DFROBOTDL/SEN0630 IMX219-79 at main · DFRobotdl/DFROBOTDL · GitHub
Jason.Miao Hello DFRobot Technical Support,
I am following up on my previous inquiry regarding the SEN0630 (WX-8M219-4Lane) IMX219 camera module.
We have completed an electrical compatibility review for connecting this camera to an Agilex 3 FPGA development board. Before powering on the hardware, we need clarification on the following safety-critical points.
1. I²C voltage compatibility (highest priority)
Our FPGA board has 4.7 kΩ pull-up resistors to 3.3 V on the camera I²C SDA and SCL lines.
The IMX219 sensor uses a 1.8 V I/O supply, and its recommended input voltage limits appear to be lower than 3.3 V.
Does the SEN0630 camera module include an onboard I²C level shifter?
Can its external SDA and SCL pins safely connect directly to a 3.3 V I²C bus with 4.7 kΩ pull-up resistors?
If not, what voltage and external interface circuitry are required?
2. Pin 6 (GPIO)
Is pin 6 connected to a power regulator enable, RESET, PWDN, or another function?
What voltage levels are permitted, and what happens when pin 6 is held Low or left floating?
3. MIPI CSI-2 four-lane mapping
Could you confirm that the SEN0630 supports four active MIPI CSI-2 data lanes and provide the exact mapping and P/N polarity from the IMX219 sensor to the 22-pin FFC connector?
4. Connector and power sequencing
Could you confirm the connector contact orientation, the required FFC cable type, and any mandatory power-up or power-down sequence?
If available, a camera-module schematic or the relevant circuit diagrams would be extremely helpful.
We have not powered on the camera because these electrical safety questions remain unresolved.
Thank you for your assistance.
Best regards,
Kato
