General PCB Services
DFR1015
userHead pgagean 2026-10-31 20:16:19 167 Views1 Replies
I am designing a PCB for the DFR1015 DC-DC multi-output buck converter (3.3/5/9/12 V), and I need the exact positions of the soldering holes.
The dimension drawing on the product page shows 23.368 mm between the left and right hole columns, and 10.922 mm between the pairs. Please confirm:
1. Is the 10.922 mm measured between the two inner holes (the lower hole of the "-" pair and the upper hole of the "+" pair), or between the first hole of each pair?
2. Is the distance between the two holes of each pair 2.54 mm?
3. Which side is IN and which is OUT?
If you have a PCB footprint (KiCad, Altium) or a 3D/STEP file for the module, I would be grateful for a link.
Thank you very much,
Paulo
2026-11-02 15:35:44
The first piece of data is the distance measured by two close holes. The second piece of data has been verified to be correct through the product page. You can check the product page and ask AI for more information. If you need files such as CAD, you will need to contact the technical support of DFRobot.
userHeadPic Jason.Miao
