I need Arduino example codes for FireBeetle2 ESP32-P4 Wi-Fi connection.
userHead HKPhysicist 2026-11-05 04:20:16 275 Views4 Replies
Hello DFRobot Support,
I am interested in this board.
https://www.dfrobot.com/product-2915.html
Since, the primary core is ESP32-P4 which does not come with a Wi-Fi feature.
So, can you show me codes example to use the on-board ESP32-C6 to connect to network?And how do I tune the main core to run at lower speed to save more power?
Yours faithfully.
2026-11-12 16:19:15
Very cool, thank you.
When I need more tweaks, I will contact you again.
userHeadPic HKPhysicist
2026-11-06 09:27:15
The ESP32-P4 has an auxiliary module of ESP32-C6, which enables the normal use of the wiki sample code.
https://wiki.dfrobot.com/dfr1172/docs/22905
userHeadPic Jason.Miao
HKPhysicist wrote:
okay, nice.
So, can we slow down ESP32-P4 to run at a lower speed such as 80MHz, sleep mode, etc.?
2026-11-10 01:28:08
Jason.Miao wrote:
​https://docs.espressif.com/projects/esp-idf/en/v6.0.2/esp32p4/api-reference/system/power_management.html
You can take a look at this link. It should be exactly what you need.
2026-11-10 10:10:15
