3× SEN0628 matrix ToF on a Maqueen Plus V3 for a wall maze: any problems?
Samdani Shaik 2026-11-20 14:20:22 16 Views0 Replies Hi all. I'm helping a team of four kids rebuild their maze robot for a competition (NYRC-style maze: 30 cm squares, matt black walls about 15 cm high).
Current robot: micro:bit V2 + Maqueen Plus V3 (18650 version), MakeCode, one SEN0628 facing forward at 0x33 (MAT mode, reading row 5). It works well facing a wall straight on.
Plan: add a left and a right SEN0628 (0x31 and 0x32) to keep the robot centred between the side walls, plus one gyro for 90° turns.
Questions:
1. Has anyone run 3 SEN0628 on one Maqueen Plus V3? Can the Gravity I2C sockets supply about 240 mA total (under 80 mA each), or do we need separate power?
2. How do the readings hold up on matt black walls at 5–15 cm when the beam hits the wall at an angle (15–45°)? Any drop-outs or jumps?
3. In MakeCode, does the matrix lidar extension work with 0x31, 0x32 and 0x33 at the same time? What read rate do you actually get per sensor with three on the bus?
4. Which gyro/IMU would you recommend with the Maqueen in MakeCode for accurate 90° turns (within ±2°)?
5. Is there a simpler or more reliable sensor choice for side walls at 5–15 cm that we should consider instead?
Thanks. Any first-hand experience is very welcome.
