FIT0701 USB Camera - Minimum Focus Distance and Manual Lens Adjustment
userHead Robert.Richard 2026-11-18 06:07:31 65 Views3 Replies
I am considering purchasing the FIT0701 USB camera module for a robotic vision project.
The camera will operate approximately 5–15 cm from objects.
Could you please confirm:
What is the minimum focusing distance of the FIT0701?
Can its threaded lens be manually adjusted to focus sharply at 5 cm?
If focused at approximately 10 cm, will objects between 5 and 15 cm remain reasonably sharp?
Do you have sample images captured at 5 cm, 10 cm, and 15 cm?
Do you also have the focal length and aperture (f-number) of the lens?
The published specifications do not appear to include the focusing distance or depth of field.
Thank you.
2026-11-18 16:27:16
The FIT0701 is a fixed-focus module: a 2.8 mm lens at f/2.8, set at the factory to focus at 60 cm. There is no focus ring, and no minimum focus distance to quote — the focal plane does not move.This product should not meet your expected requirements.
userHeadPic Jason.Miao
Robert.Richard wrote:
Thanks for the information. I've noticed that the lens on a similar camera module is threaded and can physically rotate, moving closer to or farther from the sensor. Does the FIT0701 have a mechanically adjustable threaded lens that is simply factory-set to 60 cm, or is its lens permanently fixed? I'm asking whether manual refocusing to approximately 10-15 cm is physically possible, even if it isn't officially supported.
2026-11-18 16:38:04
I also wanted to add that I have the exact camera purchased from DigiKey (DFRobot FIT0701, part number 1738-FIT0701-ND).
The PCB is marked DSJ-3808, and I've physically confirmed that its threaded lens can rotate, moving closer to or farther from the sensor.
Wouldn't this allow manual refocusing, even if the camera is factory-set to 60 cm?
Could you confirm whether the lens can be manually adjusted to focus sharply at approximately 10–15 cm?
2026-11-18 16:40:21
