Troubleshooting
KIT0210 charging batteries above 4.2V
userHead Tren3231 2026-11-17 20:01:12 20 Views0 Replies
I have two KIT0210 that both try to charge the batteries above 4.2 volts. With the USB-C connected I measure 12.82 volts across the three cells. My batteries are already at 12.71 volts when I measure them outside of the kit, they are already above the charging cutoff of 12.6 volts. The kit is still appying a higher voltage to the batteries, wouldn't this be damaging?
What could be causing this issue? Am I doing something wrong?
Thanks for any help
