General Raspberry Pi
Building a Custom Raspberry Pi CM4 Carrier Board – Things to Consider Before Designing the PCB
userHead Vaani.Jain 2026-11-24 14:58:05 61 Views1 Replies
The Raspberry Pi Compute Module 4 is a great option for building embedded products, industrial controllers, smart displays, and other custom electronics projects.
One advantage of the CM4 is that it already includes the main computing hardware. Instead of designing an entire computing platform, developers can build a custom carrier board to add the interfaces and peripherals their application requires.
However, designing a carrier board involves more than just connecting a few pins. There are several things worth considering during the hardware design stage.
1. Plan the interfaces based on your application
Think about which connections your project actually needs. Depending on the application, these might include HDMI, USB, Ethernet, audio, GPIO, UART, I²C, or SPI.
It's better to plan these requirements before starting the schematic rather than adding connectors later.
2. Pay attention to power management
A CM4 carrier board may have several power requirements. For example, the processor, USB peripherals, audio amplifier, and cooling fan can have different supply requirements.
Make sure the regulator has sufficient current capacity and consider startup loads and voltage drops when selecting components.
3. Consider thermal management
If your project runs continuously or performs demanding processing, cooling becomes important. A fan controller with PWM speed control can help adjust fan speed according to temperature and workload.
4. Don't overlook PCB layout
High-speed interfaces such as HDMI and USB require careful routing. Differential pair geometry, trace matching, ground continuity, and connector placement all influence signal integrity.
Also consider mounting holes, enclosure dimensions, and connector accessibility before finalizing the PCB.
I recently came across a practical CM4 carrier board design discussion from PCBCool, a company providing PCB manufacturing and PCBA services. It covers how different subsystems, including USB, HDMI, audio, power management, and fan control, can be integrated into a single carrier board.
Here's the detailed engineering reference: CM4 Carrier Board Design Guide
I'd love to hear from other makers and hardware developers:
If you were designing a custom CM4 carrier board for your next project, which interfaces would you prioritize?
Would you prefer a compact board with only essential connections, or a feature-rich carrier board with USB expansion, audio, HDMI, cooling, and additional peripherals?
Also, what has been your biggest challenge when designing custom carrier boards?
2026-11-26 03:09:51
Here is an interesting implementation of CM4.
https://www.pcbway.com/project/shareproject/Modular_CM4_All_in_One_Touchscreen_Mini_PC_Motherboard_8f3dec24.html
It takes a slightly different approach by integrating the CM4 socket, MIPI DSI display connection, USB-A ports, and USB-C power into a compact motherboard designed to mount directly behind a touchscreen.
userHeadPic love.forcircuits
