DFR09326 display doesn’t work
Lmitchel 2026-11-25 05:08:08 54 Views3 Replies I received these two LCD displays last week. I thought they're would be the latest version. They were version one, which you state in your internet site has been discontinued.
I wanted to use it with my Arduino uno clock to see what it is doing when it's playing its chime sequence. It didn't work at all with my uno, and it didn't work as a stand alone tied to a uno running off my laptop. Even the internet didn't show this version in you tube videos.
It didn't power up at all. I wanted to use it to duplicate what the Arduino IDE software serial monitor shows.
Everthing I looked at on the internet looked completely different than the one in the picture. Even your web site didn't show information on this version. (I might be wrong on the previous statement). I would really like to use as a serial LCD module for my clock. But I want one that works.
So, please provide me with a newer replacement, with correct instructions, so I can implement into my clock.
If you need my ardruino uno sketch, I would be willing to provide to make sure your device works with my code.
Respectfully,
Lee Mitchell
Download files , tried to install, got comp errors, the display didn’t even light up. Nothing happened.
i tried to do new sketch with only the files needed. No luck. keeo it simple stupidly didn’t work. I am ready to give up on these units.
Lmitchel
Lmitchel It seems you bought DFR0374. Please check the SKU on your order number to see what model it is. I noticed that DFR0374 is not currently out of production and is even placed together with the new version DFR0936. If they made a mistake in the shipment, you can contact the official for a return.
If you still want to use it, you can also refer to the correct wiki.
https://wiki.dfrobot.com/dfr0374
