HUSKYLENS 2 Power Board V1.0.0: Gravity "+" pin output or input? Wiring to a 3.3V ESP32
yoshio.yoshida 2026-11-25 15:37:06 37 Views2 Replies Hello,
I have a HUSKYLENS 2 (SEN0638) with the HUSKYLENS 2 Power Board (printed "V1.0.0"). I updated the firmware to 1.4.2. I want to connect it to an ESP32 development board (ESP-WROOM-32, 3.3V logic) over I2C. Before I wire anything, I would like to understand the Power Board, because ESP32 GPIO pins are not 5V tolerant.
My plan:
- HUSKYLENS 2 -> Power Board "I2C/UART" port (white 4-pin cable).
- Power Board "PWR IN" -> USB-C power.
- Power Board "Gravity" port -> ESP32 with the supplied 4-pin cable.
The Gravity port is printed, left to right: D/T, C/R, -, +.
Cable colors, in that order: green, blue, black, red.
- Planned ESP32 connections: D/T (SDA) -> GPIO21, C/R (SCL) -> GPIO22, "-" -> GND.
My questions:
1. Is the "+" pin on the Gravity port an output from the Power Board, or an input (a voltage reference)? If it is an output, what is its voltage?
2. For a 3.3V controller, should "+" be connected to the 3V3 pin, or left unconnected?
3. Are the I2C lines (D/T and C/R) pulled up on the Power Board or on the HUSKYLENS 2, and to what voltage? Is it safe to connect them directly to 3.3V GPIO pins?
4. Is D/T = SDA and C/R = SCL in I2C mode correct?
5. Has anyone connected a HUSKYLENS 2 with this Power Board to an ESP32 (3.3V)? What wiring worked?
The wiki shows diagrams only for an Arduino Uno (5V) and a UNIHIKER K10, so I could not confirm the ESP32 case.
Thank you very much for any help.
On the "+" pin of the Gravity port of HUSKYLENS 2, it serves as an input for the power board and is unidirectional. Generally, the Raspberry Pi can directly power HUSKYLENS 2. However, if the main control board has a relatively weak power supply capacity, it may not be able to power HUSKYLENS 2. In such cases, additional power supply is required on the lower right corner.
In I2C mode, D/T = SDA and C/R = SCL are correct.
Similarly, the 3.3V of the esp32 can be plugged in first for a test. If it cannot power HUSKYLENS 2, then an additional power supply via type-c can be used to power HUSKYLENS 2.
Jason.Miao
