Scaling Maker Projects to Enterprise-Grade Networks
userHead Wesley.Colton 2026-11-25 17:20:21 33 Views0 Replies
Many of us write Delphi tools that talk to small hardware setups: a handful of microcontrollers or sensors sending data over TCP, UDP or MQTT to a VCL/FMX app or a service. On the bench, a cheap unmanaged switch or home router is usually enough.
Problems start when the project grows to dozens of devices. Broadcast traffic increases, one misbehaving device can affect everything on a flat network, and there's no clean way to separate test and production hardware. It's also hard to see why connections drop.
A few things worth planning early: put devices on their own VLAN, use DHCP reservations or static IPs, consider PoE for powering sensors, and use a managed switch with SNMP monitoring. On the Delphi side, make the client tolerant of reconnects and timeouts. For reference, the Cisco 350 Series managed switches category shows the kind of features I mean (VLANs, PoE+, basic Layer 3 routing). Disclosure: I'm affiliated with ORM Systems, which hosts that page.
How do you handle segmentation and monitoring when a small device project becomes a production system? Any Indy, Synapse or MQTT tips for unreliable links?
