Wi-Fi vs. PoE: Powering and Networking Smart Sensors at Scale
Wesley.Colton 2026-11-25 17:24:50 38 Views0 Replies When a sensor project grows from a few prototypes to dozens of nodes, one of the first big decisions is how to connect and power them. Wi-Fi is quick to start with: no cabling and cheap modules. But every node still needs its own power supply or battery, and a crowded 2.4 GHz band can cause dropped connections that look like application bugs.
PoE solves two problems with one cable. 802.3af provides up to 15.4 W per port, 802.3at (PoE+) up to 30 W, and cable runs are limited to 100 m. The trade-offs are cabling effort, port count, and the switch's total PoE power budget, which is often lower than all ports combined. Many managed switches also offer VLANs and per-port power cycling, which helps when a device hangs.
It also changes how you write the Delphi side. Wi-Fi nodes tend to disconnect more often, so reconnect and timeout handling matters more than with wired devices. For hardware reference, the switches category lists models from several vendors with PoE options
How do you choose between Wi-Fi and PoE for sensor deployments, and how do you handle reconnects in your Delphi clients?
