Choosing the Right Router or Switch for a Growing IoT Deployment
Wesley.Colton 2026-11-25 17:36:36 35 Views0 Replies A switch forwards traffic inside a network. A router connects separate networks, handles NAT, firewalling and VPN, and decides what leaves the site. Mixing the two up often leads to a flat network where every sensor shares one broadcast domain with laptops and test servers.
A common growth path is a managed switch with a VLAN for sensors and another for management, plus a router or Layer 3 switch to route between them. Add dual WAN or LTE if the site needs remote access or failover. Check the PoE budget, the uplink speed, and whether the router's throughput holds up with VPN and firewall rules enabled, since datasheet numbers are often for plain routing.
For Delphi developers this affects service discovery, broadcast-based protocols and how clients reach devices across VLANs. For hardware reference, the <a href="https://ormsystems.com/routers-price.html">routers category</a> lists enterprise and small-office models from several vendors
