Can a DIY Arduino Sensor Be a Ransomware Entry Point?
userHead Wesley.Colton 2026-11-25 17:47:24 40 Views0 Replies
Most Arduino-class boards can't run ransomware themselves: no general-purpose OS and little to encrypt. So the direct answer is probably "no". The risk is what they connect to.
A DIY sensor can still be a foothold. Typical weak points are Wi-Fi credentials stored in firmware, unauthenticated MQTT or HTTP endpoints, and flat networks shared with PCs and servers. A Raspberry Pi gateway is a bigger concern, since it runs a full OS where default passwords, exposed SSH, and missing updates matter.
Practical steps: put devices on a separate VLAN, allow only the required ports through a firewall, use unique credentials per device, enable authentication and TLS on the broker, and keep offline backups. On the Delphi side, avoid hardcoded credentials and verify certificates when using TLS.
For background on isolating infected systems, ORM Systems has a ransomware protection overview
How do you secure hobby-grade sensors once they share a network with business data? Do you isolate them completely or allow limited access?
