Calibration Procedure of the SEN0711 Ammonia Nitrogen and pH Sensor.
userHead ber 2026-11-27 01:07:40 6 Views0 Replies
I have a question regarding the calibration procedure of the SEN0711 Ammonia Nitrogen and pH Sensor.
The sensor has two separate probes: a black probe and a glass probe. During ammonia nitrogen calibration (10 mg/L and 100 mg/L NH₃-N), should I immerse both probes in the ammonia standard solution, or should I only immerse the black ammonia probe?
Similarly, during pH calibration (pH 4.01 and pH 9.18), should I immerse both probes in the buffer solution, or only the glass pH probe?
I'm concerned that immersing both probes in the ammonia standard solution might affect the pH electrode's readings or calibration.
Could you please clarify the correct immersion procedure for each calibration process?
