DFR1262 flexible AMOLED: minimum bend radius and HDMI latency?
userHead elliotkaiser 2026-11-27 08:51:59 67 Views1 Replies
Hi, I'm evaluating the DFR1262 6.67" flexible AMOLED for a university research lab, driven from a Windows PC over HDMI. Two questions before ordering:
1. What is the minimum bend radius? We want to bend it permanently into a cylinder about 33 mm in radius, along the long edge, with the screen facing inward (concave side). Is that within spec?
2. What is the input-to-display latency of the HDMI driver board (HDMI in to light out)? Does it buffer full frames, and what refresh rates does it accept from a PC (e.g., 2400x1080 at 60 Hz)?
Thanks!
2026-11-27 09:59:05
This is the information I have. I hope it will be helpful to you.
Refresh rate first. The panel is specified at 50 Hz , not 60. Set the host to 2400×1080 at 50 Hz — 60 Hz is not a supported mode. The resolution is also 2400×1080 (SPR) , sub-pixel rendered, so thin text and 1 px lines will show colour fringing that a true RGB stripe would not.
Bend radius. A permanent single bend along the long axis at 47 mm radius has been confirmed to sit inside the safe range. Your 33 mm is tighter than that, so I cannot call it in spec. Two mechanical notes either way: screen-inward, concave, is the correct direction — it puts the emissive stack in compression, while screen-outward puts the thin-film encapsulation in tension and is the direction that fails first. And bend the panel area only; the FPC bonding zone and the MIPI adapter board are rigid and must stay flat, with a strain-relief loop left in the FPC.
Power. Budget about 5 V / 600 mA at peak, not the ~3 W typical figure. You can feed it from the Pi 5 40-pin 5 V rail instead of the micro-USB port, with a lead that is dupont-female on the Pi side and micro-USB on the driver board side — but the wire gauge matters: use 22–24 AWG. A thin lead drops enough voltage to cause flicker or a panel that will not light at all, which is the most common cause of the "screen flickers" symptom.
HDMI latency. No figure is published, and it cannot be quoted honestly from the documentation. The chain is HDMI → bridge board → MIPI → panel driver IC, and a bridge of this class normally buffers at least one frame, so expect 20 ms or more at 50 Hz before host compositing. Measure it in your own setup: show a running counter or trigger a flash through a photodiode and film source and panel together at 240 fps or higher.
userHeadPic Jason.Miao
