Problem with GPS/GSM/GPRS module v2.1
userHead seadra 2012-09-02 02:44:38 5789 Views2 Replies
Hello guy,I'm from Vietnam.
I have a project which use GPS. I use the code "How to drive the GPS Mode via Arduino board" in it
But It's not work, I use Serial monitor and I receive some lines like that:
$GPGGA statement information:
UTC:173407.14
Lat:-0.0000000
Dir:,
Lon:-0.0000000
Dir:,
Alt:
UTC:173412.14
Lat:-0.0000000
Dir:,
Lon:-0.0000000
Dir:,
Alt:
UTC:173417.14
Lat:-0.0000000
Dir:,
Lon:-0.0000000
Dir:,
Alt:
UTC:173422.14
Lat:-0.0000000
Dir:,
Lon:-0.0000000
Dir:,
Alt:
Somebody can tell me,what's wrong with this and how can I fix this problem ?
P/s: Sorry about my English ^^
2012-09-04 12:52:16 Hello, I had the same problem, is it not receiving a signal, get away from buildings.
I put the module in the window and it worked perfectly, with only the usb connected.
userHeadPic udelunar
2012-09-03 16:38:35 Hi,
It looks like the GPS module might not have a lock to a satelite. Are you outside or near a window? If you are arround large buildings you might have trouble locking onto a satelite. How are you providing power? and how much power? You should at least be providing 7v 1A, please don't provide more than 9V.
Also, have you inserted a SIM chip? this shield requires a SIM chip for the GPS to work.
userHeadPic Hector
