Bluetooth BEE - CTS/RTS Enable
userHead jyaron 2012-09-08 08:29:02 7440 Views4 Replies
I notice that RTS/CTS pins are avail on the Bluetooth BEE module.
However, they are not enabled.
How do I enable these hardware handshake control lines?
2024-09-11 17:51:01
[quote="Hector"]
What are you going on about?
Attached is the schematic. Read the Bluetooth module's data sheet...
[/quote]
This is certainly not the schematic for this device:
https://www.dfrobot.com/index.php?route= ... uct_id=193
and if it was, the firmware still does not honor RTS from a Host
userHeadPic jyaron
2024-09-11 17:49:53
userHeadPic Hector
2012-09-11 16:54:05 Jyaron,
It is the schematic for this device. The bluetooth bee only takes an existing bluetooth module, (for which I have provided the datasheet) and breaks out the pins in an arrangement that is compatible with the zigbee architecture.
Have you tried putting the module in AT mode? Once in AT mode you should be able to make the necessary changes.
userHeadPic Hector
2012-09-08 18:47:12 [quote="jyaron"]
[/quote]
Doesn't even support hardware handshake. What a mickey-mouse inutile device.
userHeadPic jyaron
