12VDC power for Relay Shield OK?
userHead Account cancelled 2012-07-10 10:15:51 3596 Views1 Replies
The specs say 9VDC, but there appears to be a voltage regulator chip on the Relay Shield, so can I use 12VDC to power it?
2012-07-10 21:40:13 Hi,
I believe the voltage regulator is rated for 12Vdc, but it might get pretty toasty (hot) so you should monitor the temperature on it. Ideally you should supply less than 10V.
userHeadPic Hector
