Compatibility Question
userHead Account cancelled 2012-08-16 10:18:43 4607 Views1 Replies
I had a compatibility question about my arduino project. it requires a blue tooth module and the parts I currently have are:
DFRoboto DFRduino ATMeg1280 MEGA USB Microcontroller
DFRobot Meg IO Expansion Shield V2.1 for Arduino MEGA
Cytron LCD Keypad Shield for Arduino
Cytron Mini Joystick sensor
The two bluetooth modules i was looking at were these
[url=http://www.robotshop.com/ca/productinfo.aspx?pc=RB-See-179&lang=en-US]http://www.robotshop.com/ca/productinfo.aspx?pc=RB-See-179&lang=en-US[/url]
[url=http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Dfr-10&lang=en-US]http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Dfr-10&lang=en-US[/url]
Which ones are compatible with my current hardware? If both, which is the better of the two?
Also can they fit into the Xbee com slots on the IO expansion board? I currently have the controller, expansion board and LCD stcked on top of one another.
Also, are the bluetooth modules compatible with Android, Iphone and pc operations?
2012-08-16 22:07:18 hi, We can only be sure that this module is completely compatible with your current hardware.
This version is not compatible with xbee socket.  You will need this
[url=http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Dfr-95&lang=en-US]http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Dfr-95&lang=en-US[/url]
Best
Ricky
userHeadPic R2D2C3PO
