Control DC motor using timer
userHead holmes.apprentice 2012-08-31 18:25:07 7767 Views6 Replies
Hi all,
I wanna ask something. Is it possible to control a DC motor using a timer? it means that for example the motor is running for two seconds. after two seconds, the motor will automatically stop. is that possible? Because when i tried using delay after putting the condition of the motor to move forward then the stop condition after the delay, it did not work.
it looked like this:
Forward();
delay(1000);
Stop();
any recommendation?
best regards :D
2019-02-25 17:23:26 You can run the motor clockwise for 180 seconds and stop for a while and run count clockwise for 180 seconds. userHeadPic robert.chen
2019-02-25 02:02:12 i want to do dc motor timing with ardiuino 3 minutes right 3 minute left to move left and I should stop working for a while and I have no knowledge but please help userHeadPic hamzaaliharta
2012-09-19 09:59:41 ah,it finally it works :D
just like what hector said :D
thanks a lot hector :D
now i can move on to the next phase  ;)
userHeadPic holmes.apprentice
2012-09-19 07:07:04 guys,please help me check, what is wrong with this code :(
it doesnot even work once to stop after the delay set :(
[code]
//#include <Servo.h>
int motorRight1 = 36;
int motorRight2 = 37;
int motorLeft1 = 40;
int motorLeft2 = 41;
int enable1 = 38;
int enable2 = 39;
//int motorPlot1 = 36;
//int motorPlot2 = 37;
//int enablePlot = 38;
//Servo seedOpenMotor;
//Servo seedPushMotor;
//Servo moisMotor;
  pinMode(motorRight1, OUTPUT);
  pinMode(motorRight2, OUTPUT);
  pinMode(enable1, OUTPUT);
  pinMode(motorLeft1, OUTPUT);
  pinMode(motorLeft2, OUTPUT);
  pinMode(enable2, OUTPUT);
//  naviMotor.attach(44);      // set the digital pin of the front servo
//  seedOpenMotor.attach(45);    // set the digital pin of the side servo
//  seedPushMotor.attach(46);    // set the digital pin of the rear servo
//  moisMotor.attach(47);
// Serial.begin(9600);
//  digitalWrite(38,HIGH);
//  digitalWrite(39,HIGH);
  digitalWrite(motorRight1,HIGH);
  digitalWrite(motorRight2,LOW);
  digitalWrite(motorLeft1,LOW);
  digitalWrite(motorLeft2,HIGH);
  analogWrite(enable1, 255);
  analogWrite(enable2, 255);
  delay(10);
  digitalWrite(motorRight1,LOW);
  digitalWrite(motorLeft2,LOW);
  analogWrite(enable1, 0);
  analogWrite(enable2, 0);
  delay(10);
[/code]
Please :(
sorry for the late reply anyewy.
2012-09-01 12:38:16 Holmes.Apprentice,
I am using these codes for my Motor Shield and it works how you want it to work. Moves forward for 3 Second and Stops.
Here are the codes.
[code]int ml = 7;
int el = 6;
int er = 5;
int mr = 4;
char val;
  pinMode(ml, OUTPUT);
  pinMode(mr, OUTPUT);
  Serial.begin(115200);
  if(Serial.available()){;}
  val = Serial.read();
  if (val == 'w')
      Serial.println("Moving Forward");
      digitalWrite(ml,HIGH);
      digitalWrite(mr,HIGH);
      analogWrite(el, 255);
      analogWrite(er, 255);
      delay(3000);
      digitalWrite(ml,LOW);
      digitalWrite(mr,LOW);
      analogWrite(el, 0);
      analogWrite(er, 0);
  if (val == 'x')
      Serial.println("Moving Backwards");
      delay(3000);
      analogWrite(el, 0);
      analogWrite(er, 0);
  if (val == 'a')
      Serial.println("Turning Left");
      delay(1000);
      analogWrite(el, 0);
      analogWrite(er, 0);
  if (val == 'd')
      Serial.println("Turning Right");
      delay(1000);
      analogWrite(el, 0);
      analogWrite(er, 0);
  if (val == 's')
      Serial.println("Stopping");
      analogWrite(el, 0);
      analogWrite(er, 0);
[/code]
Hope this helps.
Ali.
userHeadPic Ali.Irshad
2012-08-31 19:32:31 um...I don't know what the rest of your code looks like, but if there is no other delay between the stop instruction and the forward instruction, then you wont see the stop...
I mean this:
forward> delay> stop>>forward...
You see, no delay between the stop and forward section. So either add an additional delay to your loop or put in some conditional formatting to make sure this sequence is only executed once...
userHeadPic Hector
