Dfrobot bluetooth v3 connection failed
nazhirin 2012-10-17 18:38:29 3114 Views3 Replies hye admin,
i'm having a problem to connect the bluetooth module with samsung galaxy tab 2 7.0.
is this bluetooth module not compatible with tablet?
2012-10-22 18:55:51 Hi,
Some Bluetooth modules have compatibility issues. I'm not sure, but if you can connect to one thing, and not another, it might just not be compatible.
Hector
Hector 2012-10-17 21:38:24 i tried connect with samsung galaxy s3 that have same version with me which is 4.0.4 ICS. it worked fine with s3 but not with my tablet. when i try to connect to amarino software, the module is discoverable but connection failed. Any idea?
nazhirin
nazhirin 2012-10-17 20:06:12 Hi,
It should work with the tablet. Have you tried connecting to another device?
When you try to connect to the tablet what happens?
Hector
Hector
