xbee shield, SKU:DFR0015
userHead Account cancelled 2012-10-24 01:27:23 2838 Views1 Replies
I have bought two xbee shields. When I try to configure the xbees it says it unable to connect to modem.
both jumbers are set to the right, over usb. I have tried every possible jumper configurations.
Both modems work with another adapter from adafruit.
Any suggestions?
2012-10-30 04:43:55 Hi Maursund,
might be a dumb advice and you did that already, but did you try to program first the Xbee?
[url=http://www.ladyada.net/make/xbee/point2point.html]http://www.ladyada.net/make/xbee/point2point.html[/url]
i used the XBee USB Adapter V2 (DFR0174) to program the 2 X-bee with same PAN ID, and it worked perfectly with the DFrobot shield afterward (on both Romeo and Uno with IO expansion).
userHeadPic kyoxilbuzz
