SetID of servo CDS5516 with arduino lib
userHead dc_ou 2012-07-18 07:58:35 5307 Views3 Replies
hi,
my CDS5516 servo motor just arrived. It's so cool that we can connect several of them together. so I tried with the library for arduino to set ID of the servos, however it doesnt change anything, could anyone help me to have a look on the code?
#include <CDS5500.h>
CDS5500 SERVO;
void setup(){
Serial.begin(1000000);//init Serial baudrate
SERVO.SetID(1,2);
void loop(){
SERVO.WritePos(2,0x02FF,0x01FF);// Servo ID:1, rotate to the position:0x2FF, rotate speed:0x1FF
delay(1000);
SERVO.WritePos(2,0x0000,0x01FF);// Servo ID:1, rotate to the position:0x000, rotate speed:0x1FF
delay(1000);
if I change the ID in the loop() to 1, it runs. means that the SERVO.SetID doesnt work at all...
thank you
cheers
2012-11-14 02:26:42 The function SetID can work, but after power is off, the ID is reset. userHeadPic toddluo
2012-07-18 19:11:34 Hi,
Just to make sure, are you using the CDS driver board?
There is some software you can use to test the servos, and align them
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=cds&product_id=579]https://www.dfrobot.com/index.php?route=product/product&filter_name=cds&product_id=579[/url]
userHeadPic Hector
2012-07-18 08:57:03 after uploading the sketch to the board several times, that function worked...
lol
userHeadPic dc_ou
