Immersible pump
mymadi 2012-11-11 05:01:38 3054 Views1 Replies Hi,
I want to do a project using arduino with Immersible pump to watering my plant. I do not want to use a kit from DfRobot ;).. Just to get some information. Can or not I control the Immersible pump using the L293D or L298 driver? or any ideas?
Thanks in advanced 8)
2012-11-12 21:24:22 Hi,
You should be able to control a pump with a motor driver. Optionally you could use a relay switch to control the pump.
Hector
Hector
