GPS/GPRS/GSM simple code
maxpat 2012-08-06 13:06:37 14679 Views19 Replies Hi, I am trying to write a simple code to start using GSM function with my Arduino UNO. But without success...
[code]byte gsmDriverPin[3] = {
3,4,5};
int test=0;
void setup(){
InitGsmMode();
Serial.begin(115200); // I tried with 9600
delay(500);
void InitGsmMode(){
//Init the driver pins for GSM function
for(int i = 0 ; i < 3; i++){
pinMode(gsmDriverPin[i],OUTPUT);
digitalWrite(3,LOW);//Enable the GSM mode
digitalWrite(4,HIGH);//Disable the GPS mode
//Output GSM Timing
digitalWrite(5,HIGH); delay(1500); digitalWrite(5,LOW);
while (test<1) {
Serial.println("waiting 5 s.");
delay(5000);
Serial.println("AT");delay(10000);
SendTextMessage();
Serial.println("Finished ?");
test++;
Serial.println("End");
///SendTextMessage() ///this function is to send a sms message
void SendTextMessage()
Serial.write("AT+CMGF=1");Serial.write("\r"); //Because we want to send the SMS in text mode
delay(5000); // I put 5 s to be sure that the module has time to respond.
Serial.write("AT + CMGS = \"098415719\"");Serial.write("\r"); //send sms message,
delay(5000);
Serial.write("A test message!");Serial.write("\r");//the content of the message
delay(5000);
Serial.write(0x1A);Serial.write("\r"); //the ASCII code of the ctrl+z is 26 - I tried also with print(char(26))
delay(5000);
[/code]
I tried with write, print, println.. nothing happen, except that I get my command to the serial monitor.
Can you help me starting right ?
Thanks !
3,4,5};
int test=0;
void setup(){
InitGsmMode();
delay(500);
void InitGsmMode(){
//Output GSM Timing
while (test<1) {
delay(5000);
SendTextMessage();
test++;
delay(5000);
delay(5000);
delay(5000);
[/code]
Thanks !
2013-04-23 04:37:30 Hello,
i'm trying to get working the DFROBOT GPS GPRS GSM shield with my Arduino Duemilanove.
It's rev 3.0.
I'm trying to call from the shield to my cell, but it always says "NO CARRIER".
There is no PIN code on the SIM card in the shield ...
CAn you help me ?
I'm using this code :
[code]// #
// # Editor : Lauren from DFRobot
// # Date : 23.05.2012
// # E-Mail : [email protected]
// # Product name: GPS/GPRS/GSM Module V2.0
// # Product SKU : TEL0051
// # Version : 0.1
// # Description:
// # The sketch for driving the gsm mode via the USB interface
// # Steps:
// # 1. Turn the S1 switch to the EN(right side)
// # 2. Upload the sketch to the Arduino board
// # 3. Turn the S1 switch to the communication mode(left side)
// # 4. Turn the S2 switch to the USB side(left side)
// # 5. send AT commands via the Arduino Serial monitor
// # wiki link- https://www.dfrobot.com/wiki/index.php?title=GPS/GPRS/GSM_Module_V2.0
3,4,5};//The default digital driver pins for the GSM and GPS mode
//If you want to change the digital driver pins
//or you have a conflict with D3~D5 on Arduino board,
//you can remove the J10~J12 jumpers to reconnect other driver pins for the module!
void setup(){
InitGsmMode();
void InitGsmMode(){
//Output GSM Timing
delay(1500);
void loop(){
delay(100);
}[/code]
The jumpers J10, J11, J12 are in place on the shield
Can you help me ?
carmelo42
It's rev 3.0.
CAn you help me ?
[code]// #
// # Version : 0.1
// # Description:
// # Steps:
void setup(){
InitGsmMode();
void InitGsmMode(){
//Output GSM Timing
delay(1500);
void loop(){
delay(100);
}[/code]
Can you help me ?
carmelo42 2013-04-23 04:37:30 Hello,
It's rev 3.0.
CAn you help me ?
[code]// #
// # Version : 0.1
// # Description:
// # Steps:
void setup(){
InitGsmMode();
void InitGsmMode(){
//Output GSM Timing
delay(1500);
void loop(){
delay(100);
}[/code]
Can you help me ?
carmelo42
It's rev 3.0.
CAn you help me ?
[code]// #
// # Version : 0.1
// # Description:
// # Steps:
void setup(){
InitGsmMode();
void InitGsmMode(){
//Output GSM Timing
delay(1500);
void loop(){
delay(100);
}[/code]
Can you help me ?
carmelo42 2012-08-09 20:37:15 The command AT+CSCA is not needed sometimes, however,you should set it for safety. you can also check it with the the code gsmUsbSketch posted on WIKI.
vector
vector 2012-08-09 20:37:15 The command AT+CSCA is not needed sometimes, however,you should set it for safety. you can also check it with the the code gsmUsbSketch posted on WIKI.
vector
vector 2012-08-09 20:30:08 hi,maxpat:
as you problems,i am also puzzled....but you can try to restart you uno borad, the beta version posted by lauren haven't check whether the AT commands are successful executed.
at last, the right format of set PIN is AT+CPIN=0000, No colon ”.
vector
vector
vector 2012-08-08 18:02:07 Good news and bad news !
1) It's working well with my wife ANTEL SIM (I am from Uruguay)
2) It' NOT working with my ANTEL SIM - Same contract. I can send SMS from coolterm :
Call Ready
AT OK
AT+CSCA? +CSCA: "+59899998932",145
OK
AT+CMGF=1 OK
AT+CMGS="098415711" > test
+CMGS: 96
OK
but with your program, nothing happen. I check the CSCA, it's the same (normal)
What did I dfrobot ?
With another SIM, from Claro, I can send SMS from my phone but not from coolterm or your program.
The 3 do not have PIN. Speaking of PIN, what could be the text ? I tried with
char CMD_PIN[]={'A','T','+','C','P','I','N','=','"','0','0','0','0','"'}; with ou without " but i doesn't work.
Many thanks for you help.
maxpat
Call Ready
AT OK
OK
AT+CMGF=1 OK
+CMGS: 96
OK
maxpat 2012-08-08 18:02:07 Good news and bad news !
Call Ready
AT OK
OK
AT+CMGF=1 OK
+CMGS: 96
OK
maxpat
Call Ready
AT OK
OK
AT+CMGF=1 OK
+CMGS: 96
OK
maxpat 2012-08-08 05:48:40 Thank's ! I tried it and i worked 1 time ! I have to figure out why !
1 question : AT+CSCA is mandatory ?
Max
maxpat
Max
Max
maxpat
Max
maxpat 2012-08-08 03:02:17 Here's a sketch for using GSM shield and a button to send message to the target phone.
This is the beta version.
[code]
// # Date : 07.08.2012
// # Version : Beta
// # Compatible with the Arduino IDE 1.0
// # Description:
// # The sketch for sending message by using GSM/GPRS/GPS shield
#define S_PIN 8 //set the pin ,you can change according you situation;
char CMD_SetMess[]="AT+CMGF=1"; // for more details about the command meaning, please search in the AT command document
char CMD_SetMessCenter[]={'A','T','+','C','S','C','A','=','"','1','3','8','0','0','2','1','0','5','0','0','"'};
//set China Mobile SMS center number;you can change according actual situation ,Here we take Shanghai as an example .
char CMD_SendMessage[]= {'A','T','+','C','M','G','S','=','"','1','0','0','8','6','"'};
//set the target phone Number - e.g. AT+CMGS="133911xxxxx"
char Message_Con[]="Test message from DFrobot!";//The content of message;
byte gsmDriverPin[3] = {3,4,5};
Serial.begin(19200);
InitGsmMode(); // Initial Gsm-Module
Serial.println("AT"); // Init serial to Gsm shield
delay(200);
Serial.print(CMD_SetMess);
Serial.write(0x0D);
Serial.print(CMD_SetMessCenter);
Serial.write(0x0D);
delay(20);
if(digitalRead(S_PIN)==HIGH) // use a button to trigger the function and send the message
delay(20);// To eliminate jitter
if(digitalRead(S_PIN)==HIGH) // if pressed the button, run the next step
while(digitalRead(S_PIN)==HIGH); // if released the button, run the next step
Serial.print(CMD_SendMessage);
Serial.write(0x0D);
Serial.print(Message_Con);
Serial.write(0x1A);
delay(200);
//-----------------Initial GSM Module Part---------------//
void InitGsmMode()
delay(1500);
delay(1500);
[/code]
Lauren
[code]
// # Version : Beta
// # Description:
delay(200);
Serial.write(0x0D);
Serial.write(0x0D);
delay(20);
Serial.write(0x0D);
Serial.write(0x1A);
delay(200);
void InitGsmMode()
delay(1500);
delay(1500);
[/code]
Lauren 2012-08-08 03:02:17 Here's a sketch for using GSM shield and a button to send message to the target phone.
[code]
// # Version : Beta
// # Description:
delay(200);
Serial.write(0x0D);
Serial.write(0x0D);
delay(20);
Serial.write(0x0D);
Serial.write(0x1A);
delay(200);
void InitGsmMode()
delay(1500);
delay(1500);
[/code]
Lauren
[code]
// # Version : Beta
// # Description:
delay(200);
Serial.write(0x0D);
Serial.write(0x0D);
delay(20);
Serial.write(0x0D);
Serial.write(0x1A);
delay(200);
void InitGsmMode()
delay(1500);
delay(1500);
[/code]
Lauren 2012-08-07 09:56:33 Hi,
I just got this module, though mine says v2.1.
Attached this to an Arduino.
As soon as I plugged in the 12v supply to the Arduino, one of the capacitor on the GSM board sparked and smoked.
The ratings say that it is capable of handling 6-12v. Any issues reported on the new version boards?
Some advice here would be helpful as I have another 3 of these. Would like to know about any issues before plugging in any power supply.
Thanks,
Utsav
utsavdrolia
Thanks,
Utsav
utsavdrolia 2012-08-07 09:56:33 Hi,
Thanks,
Utsav
utsavdrolia
Thanks,
Utsav
utsavdrolia 2012-08-06 23:02:25 Hi,
We're preparing the Arduino sketch for driving the GSM shield to send message. Tomorrow, I'll post the beta version sample. You could take a look.
R2D2C3PO
R2D2C3PO 2012-08-06 23:02:25 Hi,
R2D2C3PO
R2D2C3PO 2012-08-06 13:06:37 Hi, I am trying to write a simple code to start using GSM function with my Arduino UNO. But without success...
3,4,5};
int test=0;
void setup(){
InitGsmMode();
delay(500);
void InitGsmMode(){
//Output GSM Timing
while (test<1) {
delay(5000);
SendTextMessage();
test++;
delay(5000);
delay(5000);
delay(5000);
[/code]
Thanks !
maxpat
3,4,5};
int test=0;
void setup(){
InitGsmMode();
delay(500);
void InitGsmMode(){
//Output GSM Timing
while (test<1) {
delay(5000);
SendTextMessage();
test++;
delay(5000);
delay(5000);
delay(5000);
[/code]
Thanks !
maxpat
