2A Motor Shield + Graphic LCD4884 Shield??
keoppo 2013-04-24 02:14:02 5631 Views5 Replies Hi,
I'm an Arduino newbie here and i have an Arduino Uno with the "2A Motor Shield For Arduino" (Product Code: DRI0009) hooked up to a stepper motor.
I was wondering if it is possible to stack the "Graphic LCD4884 Shield For Arduino" (Product Code: DFR0092) onto this? Will they interfere with each other?
Thanks in advance
Vincent
Thanks in advance
Vincent
2013-05-30 15:46:34 Thank you two so much, it was hard to understand without having the actual board. But it all worked out! Thanks again for your explanations Pheobe and Jose!
keoppo
keoppo 2013-05-17 20:51:20 You could stack the shields just fine. But you would need to plug some wires in the jumpers Phoebe mentioned. Female to female like:
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=wire&page=2&product_id=873]https://www.dfrobot.com/index.php?route=product/product&filter_name=wire&page=2&product_id=873[/url]
Wires from the jumpers on the motor shield to the digital pins 8,9,10,11 on the LCD digital pins on the side.
Jose
Jose 2013-05-14 19:12:18 Sorry for a silly question, does that mean i cannot stack the shields together?
keoppo
keoppo 2013-04-24 18:50:17 Hi
Yes, but you should pay attention to pin using. The LCD shield use pin 2,3,4,5,6,7. The Motor shield use pin 4,5,6,7 default. But you can change pins of motor shield to 8,9,10,11. Just take off the 4 jumper caps and use jumper cable to connect to Digital 8,9,10,11 ;)
Best
Phoebe
Best
Phoebe
