Arduino DUE and Color sensors!
userHead Account cancelled 2013-05-31 07:03:56 3076 Views1 Replies
Hello! I'm planning to use an TCS3200 color sensor for a project, that if it's succesful i'll post it. But, first i wold like to know if i can use this sensor with the DUE, i've been searching and it seems to be a chaos about sensor colors and DUE. Is it a good idea to use this sensor? Do you recommend another one? Thank you!
2013-05-31 18:04:21 Hi
The TCS3200 color sensor works at 2.7 to 5.5V , it should be compatible with DUE. I have used the this sensor with UNO & it's fine. Hope it is useful for you. ;)
Best
userHeadPic Phoebe
