How to set up a ROMEO project in Arduino Sketch
userHead Account cancelled 2013-06-05 01:47:41 3635 Views1 Replies
How do I connect this board to my computer? I am assuming the micro USB port? And what type of board do I select under Tools->Board? Other than installing the stepper motor library, is there anything else I need to do to get started with programming this board?
2013-06-05 01:55:29 Hi,
The board selection depends on the Romeo version. You can check the wiki for information under the software tab:
[url=https://www.dfrobot.com/wiki/index.php?title=Special%3ASearch&search=romeo&fulltext=+]https://www.dfrobot.com/wiki/index.php?title=Special%3ASearch&search=romeo&fulltext=+[/url]
Just connect the USB, and a good starting point would be to try the blink example on the Arduino IDE.
userHeadPic Jose
