URM04 V2.0 How to assign a different ID
userHead megabugger 2013-06-12 14:24:07 4996 Views7 Replies
Sorry for my English.
google translator.
We need to do a network of multiple sensors URM04 and read the data.
I can not set a different ID than the default.
How to do it.
Please tell me with examples.
2013-06-18 00:23:34 the arduino code is not working?
the PC software you wrote is same method as the arduino example code?
I'm glad it is working  :)
userHeadPic Jose
2013-06-17 22:49:04 Thank you. Problem was solved. Wrote the software for the PC and changed the ID, sensors. With the aid of Arduino to change ID, and did not work. userHeadPic megabugger
2013-06-17 20:45:21 What do you mean? userHeadPic Jose
2013-06-15 14:06:59 I soon this wiki page with heart'll declare.
He does not want the sensor to change your ID.
Why ask for help. Maybe there is some sort of software for the PC to change the ID
2013-06-14 20:00:44 found this:
[url=https://www.dfrobot.com/wiki/index.php?title=URM04_V2.0_(SKU:SEN0002)#Set_Device_Address]https://www.dfrobot.com/wiki/index.php?title=URM04_V2.0_(SKU:SEN0002)#Set_Device_Address[/url]
i hope this helps.
However i have not tried yet..
userHeadPic Jose
2013-06-14 14:21:21 Well, you could say that.
PC <=> Arduino <=> converter RS232 to RS485 <=> URM04
In Arduino two functions:
1. USB to RS232 converter
2. Poll sensors and send the information in a specific format to RS232
While the dough using a 4 ultrasonic sensor (hereinafter 16).
So, I need to poll each sensor individually.
2013-06-14 00:15:18 Hi,
How are you connecting the URM32?
Serial port?
Best,
Jose
userHeadPic Jose
