GPS Shield LEA-6H
userHead struct 2013-10-24 23:29:23 3727 Views4 Replies
Hi there,
I recently purchased a DFRDuino GPS shield (with Ublox LEA-6H module), and have tried using the [url=http://"http://www.dfrobot.com/wiki/index.php/DFRduino_GPS_Shield-LEA-5H_(SKU:TEL0044)"]sample code[/url] provided, however the results that are being printed to the Serial Monitor don't make a lot of sense:
[code]DFRobot DFRduino GPS Shield v1.0
$GPGGA statement information:
UTC:151528.00
Lat:inf
Dir:,
Lon:-440400288.00000
Dir:,
Alt:inf[/code]
My serial baud rate is 9600. I am using an Arduino Uno with using Arduino 1.0.5, and have also tried Arduino 1.5.4 - both yield the same result. I've tried using TinyGPS++ library, however it says it can't find a GPS module. I've disconnected the jumpers when uploading, and reconnected them after the upload has finished.
Really appreciate any help with this. I can provide more information if necessary.
2013-10-28 21:52:36 **, nice link! I like it already
Thanks^^
userHeadPic Jose
2013-10-25 22:21:51 Yeah, Sometimes GPS performs too poorly inside buildings.
Here is guide about GPS indoor.
https://blog.itu.dk/FCTUC-F2010/files/2010/03/kjaergaard-indoorgpspervasive2010.pdf
userHeadPic Grey.CC
2013-10-25 20:28:56 Hi Grey
I took it outside for 5 minutes and it started working, brought it back inside again and it started to work. However it seems very susceptible to interference. What sort of things should I keep it away from? Thanks for your help.
userHeadPic struct
2013-10-25 19:09:45 Hello, struct
It looks like work, but the date is not correct. Are you indoor? or signal is not very well.
When  GPS module is indoor, or signal is disturb. It can't find the satellite
userHeadPic Grey.CC
