controlling the motor through sms with GPS/GPRS/GSM V3 Arduino UNO
userHead karaeng_android 2013-10-22 02:21:57 4825 Views3 Replies
please help make a listing for controlling the motor through sms with GPS / GPRS / GSM V3
please listings receive sms, read, and approved the process sms and delete sms :(
2013-11-04 23:40:24 sorry grey longtime not login to forum becuz i'm very busy...
yes grey...motor Controlling but without PWM...
thx for reply...i will try it... :)
userHeadPic karaeng_android
2013-11-01 21:21:28 Hello karaeng_android
Have you still working on this issue?
I write a sketch about how to control arduino by GSM module.
when I input the message by myself via serial port, it works fine, but l plug the module on the arduino
it won't work.And what I input is what module outputs. It has been bothering me for a long time.
[code]#include <Wire.h>
#include <Arduino.h>
#define S_IDLE 0
#define S_ATOK 1
#define S_GETMESSAGE 2
#define S_READMESSAGE 3
#define M_ATOK "OK"
#define M_GETMESSAGE "+CMTI"
#define M_READMESSAGE "+CMGR"
#define M_CALLREADY "Call Ready"
#define M_FLAG "DF"                      //DF the the flag to position the Command in the data recevied by Serial port.you also can change it using other flag.
char messageCMD[2]="";                  //using to hold Command,for example,if the value is H8,stands the pin 8 will output a high level.
String comdata = "";
int gsmDriverPin[3] = {10,11,12};
int messageControlPin[7]={3,4,5,6,7,8,9};
void setup(){
  Serial.begin(9600);                  // The rate should not too high.It's ralated with the delay time of reading data from the Serial port.
  for(int i = 0 ; i < 3; i++)
    pinMode(gsmDriverPin[i],OUTPUT);
  digitalWrite(12,HIGH);
  delay(1500);
  digitalWrite(12,LOW);
  digitalWrite(10,LOW);              //Enable the GSM mode
  digitalWrite(11,HIGH);            //Disable the GPS mode
  delay(5000);//need test
  Serial.print("AT");
//Serial.write(0x0D);
  Serial.print("ATE0");            // echo off
//    Serial.write(0x0D);
  delay(20);
  Serial.print("AT+CMGF=1");        //Set the format of message to Text Mode
  delay(20);
  Serial.print("AT+CNMI=2,1,0,0,0"); //Set new SMS message indications
  delay(20);
  delay(100);
  for(int i=0;i<7;i++)
    pinMode(messageControlPin[i],OUTPUT);//Initial the controlled pin
void loop(){
  String event_message="";
  int at_event=0;
  while(1)
    event_message=SerialDataRead(event_message);
    event_message=SerialMessageCheck(event_message,&at_event);
    MessageCommand(&at_event,messageCMD);
//---------------------------Read data------------------------------------//
String SerialDataRead(String MessageData){
  while(Serial.available()>0)        //serial data read
    char CharRead=Serial.read();
    if(CharRead!=10&&CharRead!=13)
      MessageData=MessageData+CharRead;
    delay(5);
return MessageData;
//-----------------------------Check data---------------------------------------//
String SerialMessageCheck(String Message,int *Event){
  if(Message.indexOf(M_ATOK)!=-1)      //check AT OK
    Message="";
    *Event=S_IDLE;
  else if(Message.indexOf(M_CALLREADY)!=-1)  //check CALL READY
    Message="";
    *Event=S_ATOK;
  else if(Message.indexOf(M_GETMESSAGE)!=-1)
    Message="";
    *Event=S_GETMESSAGE;
    delay(20);
  else ;
  return Message;
//----------------------The most important part!----------------------------//
void MessageCommand(int *Event,char *messageCMD) {
  if(*Event==S_GETMESSAGE)                    // when get new SMS,execute follows
    Serial.print("AT+CMGR=1");                //Attention,we will read the message from zone No.1
    delay(20);
    while(Serial.available()<1);
    while(Serial.available()>0)              //Read out the data that has just been print,AT+CMGR=1.
      delay(5);
    comdata="";
    while(Serial.available()<1);            //waiting data.......
    while(Serial.available())
      char CharRead=char(Serial.read());
        comdata +=CharRead;
      delay(2);
    int messageIndex1=comdata.lastIndexOf(M_FLAG);
    if( messageIndex1!=-1)
      for(int i=0;i<2;i++)
        messageCMD[i]=comdata[messageIndex1+2+i];
      comdata="";
    *Event=S_READMESSAGE;
    if(*Event==S_READMESSAGE)
      if(messageCMD[0]=='H'||messageCMD[0]=='h')
        digitalWrite(int(messageCMD[1]-'0'),HIGH);
      if(messageCMD[0]=='L'||messageCMD[0]=='l')
        digitalWrite(int(messageCMD[1]-'0'),LOW);
    Serial.print("AT+CMGD=1");                    //deleted the Received SMS message  in Card.
    delay(20);
    *Event=0;
[/code]
userHeadPic Grey.CC
2013-10-24 00:24:28 Hello, karaeng_android
What do you want to do?
Just control the motor?  PWM motor control?
And you just want to control it by your phone message,right?
userHeadPic Grey.CC
