Romeo v1.1 power supply via VIN
userHead bahbka 2013-07-10 04:29:09 5717 Views4 Replies
Hello!
I stuck with a little problem with Romeo v1.1, when I supply power via VIN and GND on the board I got ~3.5V on other 5V pins (same with MVIN). When I supply power via USB or Power Jack I got 5v on all 5V pins. There is no such problem with Romeo v0.9 (ATMega168 version). Any advice, please?
Thanks!
2013-07-13 02:44:21 I'll try this, thank you again! userHeadPic bahbka
2013-07-11 23:45:57 Hi
There is a way that you can power 5V directly to the analog pin '' 5V & GND''. So that you can get 5V from digital & Analog pins.
Best
userHeadPic Phoebe
2013-07-10 21:22:56 Yes, I just power 5V. I guessed this, thank you! :)
There is no way to power Romeo with regulated 5V without using Power Jack or USB? Powering via jack or USB look a bit ugly in my project, but if there is no way - I'll use it.
userHeadPic bahbka
2013-07-10 18:49:41 Hi bahbka
If you want to use VIN or MVIN to power supply, the voltage should between 7 to 12V . I think you just power 5V
, so the IO pins just get 3.5V ;)
Best
userHeadPic Phoebe
