IO Expansion Shield For Arduino Mega V1.2 and xbee S1 code upload
userHead lt89 2014-03-27 17:57:46 4455 Views3 Replies
i have the dfrobot expansion shield V1.2 and a funduino mega 2560 R3 and i also have two series 1 xbees. I programmed both xbees through x-ctu and uploaded the example physicalpixel on my arduino with usb cable and xbee removed from shield. when i put the xbee back in the shield and plug in a 9v external supply and plug in the other xbee through the pc with the xbee explorer when i press H and L the light on arduino light up and turns off so my xbees are comunicating no problem. my issue now is when i go through the arduino ide and select the com port of the xbee and click upload after the code compiles and wants to upload i get
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer?
what am i doing wrong?
this is how i configured my xbees
xbee transmitter (pc)
PanID: 4136
DL: 10
MY: 11
Baudrate: (7) 115200
D3 DIO3 configuration: (3)DI
IC DIO change detect: 8
DD Type identifier:10000
Xbee receiver (arduino)
PanID: 4136
DL: 11
MY: 10
D3 DIO3 configuration: (5)DO high
IA IO input address: FFFF
IC DIO change detect: 0
thanks.
2014-03-28 18:41:38 Hello,
I am sorry,
xbee S1 doesn't support the wireless programming.
If you are interested in the wireless programming project.
I think you could try our BLE-LINK: [url=https://www.dfrobot.com/index.php?route=product/product&filter_name=BLE&product_id=1073#.UzTgD_lyDFI]https://www.dfrobot.com/index.php?route=product/product&filter_name=BLE&product_id=1073#.UzTgD_lyDFI[/url]
And I have written a post about it: [url=https://www.dfrobot.com/forum/index.php?topic=17274.msg21490#msg21490]https://www.dfrobot.com/forum/index.php?topic=17274.msg21490#msg21490[/url]
You can take a look.
userHeadPic Grey.CC
2014-03-28 17:33:27 [quote="Grey"]
Do you want to do a wireless programming?
Upload the sketch with Xbee?
Or just upload the sketch to Arduino via USB?
[/quote]
yes i want to do wireless programming of my arduino, upload the sketches with xbee. i only uploaded the PhysicalPixel sketch through usb to confirm that the xbee radios were talking to each other.
userHeadPic lt89
2014-03-27 19:38:53 Hello,
userHeadPic Grey.CC
