Reflash Arduino RoMeo 1.1 Bootloader?
userHead kootsoop 2014-03-31 09:49:47 3774 Views3 Replies
I just took out my DFRobot + RoMeo 1.1 kit, and restarted it for the first time in a while.
I now have a problem communicating via USB to the device, and I believe it's because the bootloader has gone bye-bye (if I hit the reset button, then the L LED does not flash at all). Also, using the serial monitor, I can hit send and see the RX LED light up, but the TX LED never lights.
So:
1) Does it sound like the bootloader?
2) How do I reflash the bootloader on RoMeo 1.1?
Pointers / suggestions appreciated!
2014-03-31 20:12:00 Yeah, I want know whether it show Arduino UNO (COM3) in the device management.
I am afraid the chip is broken.
userHeadPic Grey.CC
2014-03-31 19:14:07 The USB port shows up as COM3 in the device manager (under Windows 8.1).
I tried connecting another Arduino on the same setup, and it works fine.
Do you mean a screenshot of the Device Manager?  I think the USB driver is fine, because the other Arduino board works fine.
I tried cycling through (with Device Manager) all the possible baud rates available, but none made any difference.
userHeadPic kootsoop
2014-03-31 18:40:20 Hey,
Could you check the device manager?
Is there anything in the device manager? Like the ATmega32U4?
Could you attach a screenshot?
Anyway, what is your operating system?
userHeadPic Grey.CC
