ph meter problems
userHead ayu69 2014-03-30 02:18:58 3878 Views5 Replies
Hello
I can contact you because I buy a kit ph meter (SEN0161)
and whatever I do that it shows me 17.3 ph
yet the connection is ok I do not know what to do
thank you kindly help me
cordially
2014-07-24 18:40:25 Hello Ayu,
Please connect DFRobot techsupport mail: [email protected]
It is better to attach your order number and detail issue.
userHeadPic Grey.CC
2014-07-23 06:41:20 Hello there
so I try to change the number of the analog pin did change anything
I then try with another arduino, and nothing did change the values ??remains at 17.3
I think the module is H.S
userHeadPic ayu69
2014-07-21 19:37:23 Hello Ayu,
Could you attach a photo about your hardware connection?
It is better to change another Analog pin, and try again. Because 17.3 convert to voltage is almost close to 5V. So your analog pin has been set high.
userHeadPic Grey.CC
2014-07-20 08:16:09 Hello there
sorry if I put the time I take care of a lot of things
First of all ph meter is supplying 5VDC
but when I connect the two pins I always show 17.3 ...
userHeadPic ayu69
2014-03-31 20:00:31 Hello, Ayu
Could you use a cable to connect two BNC pins together?
The PH value will be 7 at that time.
And please check the voltage. it needs very accurate 5V power supply.
userHeadPic Grey.CC
