Re: Configuration failed on Arduino Uno R3 with Wifiz210 v2.2
userHead Lauren 2012-11-29 23:36:25 8086 Views4 Replies
Try to program a led blinking sample for your Arduino Uno board without using the serial port to avoid the conflict from the serial communication.
Generally speaking, the serial communication between Wifi shield and USB should be fine!
Regards,
Lauren
2014-08-12 00:34:39 [quote="ahlik1990"]
Hi Lauren,
I am newbie on this wifi shield. i had tried the solution you provided in the link [url=https://www.dfrobot.com/wiki/index.php/WiFi_Shield_V2.2_For_Arduino_(SKU:TEL0047)]https://www.dfrobot.com/wiki/index.php/WiFi_Shield_V2.2_For_Arduino_(SKU:TEL0047)[/url]
after everything done until set the serial monitor to Both NL&C and baud rate to 115200 bps, i tried to key in "AT" at the space given and then press send. i found nothing is response. do you have any idea on this?
[/quote]
Hi, please check if you config the switch in the right side? And how about the programming you used for your Arduino
userHeadPic Lauren
2014-08-09 21:35:18 Hi Lauren,
userHeadPic ahlik1990
2012-12-20 00:12:57 Hi James,
Sorry for the late reply. I spent some time to create a step by step tutorial for WIFI shield v2.2 from DFRobot these days. Hope it's useful for you to config the WIFI shield.
Look forward to your reply.
userHeadPic Lauren
2012-12-13 22:54:05 1. Try to config the wifi shield connected to the router first. Please take care to save the setting for the wifi shield. Otherwise, when disconnect power or press reset button, the configuration for the wifi shield via USB will lose.
2. Set the switch to the 'Arduino' side to enable the communication between the Arduino Serial and Wifi shield Serial port and disable the USB to Wifi shield communication at the same time.  :)
Regards,
Lauren
userHeadPic Lauren
