Adding the DFRobot Relay Shield to the stack
Account cancelled 2014-08-09 09:01:21 2236 Views1 Replies I have the Arduino UNO R3, also have a Arduino Ethernet Shield stacked on top of that. I need to add the DFRobot Relay Shield on to the setup. In trying to put it on the stack I see a few pins not connecting so how do I put this on there, what is to happen with the missing pins. What is affected.
2014-08-11 18:30:56 Welcome spicetraders,
That is no problem, they are I2C interface.
If you don't use it, you can leave them.
Grey.CC
Grey.CC
