Veyron Servo Driver - Servo Power
userHead Account cancelled 2014-09-01 12:31:36 1919 Views1 Replies
In the product page, Servo power interval is between 4.8 and 6V.
Why is not possible to feed different voltage e.g. 7.2 volts for the servos ?
The servo power rail is separated from the logic rail right ? why the limit ?
Tiago
2014-09-01 19:40:10 Hello,
Sorry for the confused. It is not only 4.8~6V. The voltage depends on your servo rated voltage.
For example, if your servo is 7.2V/1A, you can give it a 7.2V power supply.
And logic power is separated from servo one. You know the peak current will be very high, if you power it from a same battery, sometime it will cause the logic voltage down, then it will lose control.
userHeadPic Grey.CC
