Industrial pH Electrode - Armor Casing
$49.50
SKU: FIT0348
The pH electrode features a low-impedance glass membrane for precise measurements from 0-14pH, with fast response and thermal stability, suitable for industrial use.
Purchase this product and earn 495 reward points, which are tied to VIP membership program. Learn More >
This pH combination electrode is made of a sensitive glass membrane with low impedance. DFRobot Industrial pH Electrode - Armor Casing can be used in a variety of PH measurements with fast response, good thermal stability. It has good reproducibility, difficult to hydrolysis, and basically eliminates the alkali error. In the 0 to 14pH range, the output voltage of the electrode is linear. The reference system which consists of the Ag/AgCl gel electrolyte salt bridge has a stable half-cell potential and excellent anti-pollution performance. The ring PTFE membrane is not easy to be clogged, so the electrode is suitable for long-term online detection.
Note: This is a probe only, and it could be an upgrade part for Analog pH Meter (SEN0161). If you need an industrial long-term pH sensor directly, please check the Industrial pH Meter Kit Pro (SEN0169). And the output voltage feedback is from 0 to 5v to indicate pH value from 0 to 14.
The electrode is suitable for all kinds of printing, circuit board factory, wastewater containing chromium, and other industrial and domestic sewage pH monitoring.
  • Length (with protective cover):17.7cm(6.97")
  • Diameter:2.74cm(1.08")
  • Wire Length:5m(196.85")
  • Connector: BNC
  • Measuring Range:0-14pH
  • Measuring Precision: ≦0.02pH
  • Suitable Temperature: 0-60℃
  • Response Time:10sec
  • Drift:≦0.02PH/24hours
  • Resistance of Sensitive Membrane: ≦200*106Ω
  • Slope: ≧95 %
  • Electrode's Equipotential Point:7±0.5PH
  • H-101 pH electrode ×1
  • pH electrode manual ×1
Selection Guide for DFRobot pH Sensors
Blog Selection Guide for DFRobot pH Sensors
Jan 13, 2025
Premjit.Tarafdar Apr 20, 2026
excellent build quality and stable hardware. recommended. Very long life
Kyle.Taylor Nov 29, 2025
easy and quick setup
Out Of Stock
