2.4GHz Mini Wireless QWERTY Keyboard with TouchPad is a compact wireless control solution designed for single-board computers and mini PCs. This handheld keyboard–air mouse combo connects through a USB receiver and operates over a stable 2.4 GHz link, providing convenient navigation for media systems, development boards, and embedded computing platforms such as Raspberry Pi, Cubieboard, Mini PC, and other compatible systems. The compact HTPC input controller integrates a full QWERTY layout and touchpad in an ergonomic handheld form, enabling comfortable couch‑side control of multimedia interfaces, terminal sessions, and IoT dashboards.
Note: After 3 minutes without operation, the keyboard automatically enters sleep mode. Press any key for about 1 second to wake the unit. Lithium‑ion batteries cannot be shipped by the warehouse, therefore the keyboard is delivered without the battery. A compatible battery must be purchased separately before use.
Compact Wireless Keyboard and Touchpad Integration
This portable HTPC keyboard integrates a full QWERTY layout with a responsive touchpad, combining typing and pointer control in a single handheld unit. The large touch surface enables cursor navigation, gesture input, and convenient media interaction without requiring a separate mouse. Such integrated control hardware is especially practical for living‑room computing setups, media centers, and embedded system terminals where traditional keyboards and mice are inconvenient.
Stable 2.4GHz Wireless Connectivity
The wireless input controller communicates through a 2.4 GHz RF connection using a USB receiver, supporting reliable operation up to 15 meters without directional limitations. GFSK modulation and multi‑channel transmission improve stability in crowded wireless environments. This wireless keyboard solution enables flexible control of development boards, compact PCs, and digital signage systems from across a room or workspace.
Ergonomic Handheld Design for Media Systems
An ergonomically shaped handheld enclosure allows comfortable operation with both thumbs while holding the controller in the air. Such a design makes the mini keyboard particularly suitable for HTPC systems, Android TV boxes, and console‑style media environments. Lightweight construction and compact dimensions also make the portable wireless controller easy to carry alongside embedded platforms used in demonstrations, testing benches, and portable computing kits.
Integrated Power Management for Portable Use
The wireless keyboard module supports rechargeable lithium‑ion battery operation and includes an onboard charging circuit for convenient power management. A built‑in sleep mode reduces power consumption when inactive, helping extend standby duration in portable deployments. Such low‑power operation is well suited for home theater controllers, mobile demo systems, and compact development environments that benefit from rechargeable handheld input hardware.
This handheld wireless keyboard controller is widely used for HTPC control, embedded Linux terminals, IoT dashboards, and compact workstation setups. Compatibility with Raspberry Pi, Cubieboard, and other mini PC platforms makes the wireless touchpad keyboard a convenient interface tool for makers, developers, and multimedia system builders working with small computing platforms.
