IOT|HOME Automation | MQTT Server with Pi, LCD and Camra
In this tutorial series we will biuld a Pi hub with MQTT broker.
Hardware needed:
Note: The camera is compatible with all models of Raspberry Pi 1, 2, 3, and 4, but not suitable for Raspberry Pi 5.
Dec 30, 2020
I purchased this for my Anet A8 so I can monitor my 3D prints remotely using Octoprint on my Raspberry Pi 4B - I chose this camera on a recommendation by a friend who is using the same setup. The resolution on this camera is sufficient for my purposes, which are not for close-up inspection of the part being printed, but to be able to tell if/when a print has failed or the printer has malfunctioned. The cable it comes with is a little short, which is fine if your Pi is mounted on the frame.
