Mini Breadboard with 170 Tie Points is a compact solderless prototyping platform designed for quick circuit experimentation and small embedded electronics projects. This miniature prototyping board provides 170 connection points arranged in a simple grid, enabling rapid assembly of temporary circuits without soldering. The small breadboard fits easily onto development shields and inside space‑constrained prototypes, making the compact electronics breadboard suitable for rapid testing, sensor interfacing, and educational electronics builds. Strong adhesive backing allows the tiny circuit prototyping board to mount securely onto project enclosures, robot chassis, or larger development boards used with platforms such as Arduino.
Compact 170‑Point Prototyping Layout
This miniature solderless breadboard provides 170 tie points arranged in a 17 × 5 × 2 structure, offering an efficient layout for building simple electronic circuits. The compact electronics prototyping board supports common through‑hole components such as resistors, LEDs, transistors, and jumper wires while maintaining a footprint small enough for portable projects. The small form factor makes this rapid‑prototyping board ideal for stacking alongside controller shields, testing sensors, or building modular electronics assemblies where workspace on the main board remains limited.
Self‑Adhesive Mounting for Stable Integration
A durable adhesive backing allows this solderless circuit board to attach firmly to flat surfaces such as controller shields, enclosures, robotics platforms, or project panels. The self‑adhesive electronics breadboard stays securely positioned during prototyping and testing, reducing movement that could loosen jumper connections. This compact prototyping module also aligns conveniently with common development accessories such as Arduino proto shields, enabling organized component placement while maintaining easy access to circuit nodes for quick modifications during experimentation.
This compact solderless breadboard enables efficient circuit experimentation for embedded systems, robotics prototypes, and educational electronics builds. The small electronics prototyping board serves as a convenient platform for temporary circuits, component testing, and quick hardware iterations before final PCB design. Strong adhesive mounting and dense connection points make the miniature breadboard especially useful in portable prototypes, classroom demonstrations, and compact IoT hardware development.
Basic Parameters
Physical Dimensions
Nov 19, 2021
This product arrived, well packaged, exactly as advertised; and, is a great product for DIY, hobbyist, or professional prototyping!
Sep 17, 2020
thx sooo much that the package comes at the same day that we have holidays the sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo mutch
