Gravity: GUVA-S12SD Analog UV Light Sensor (200-370nm, UVA, UVB, UVC)
$5.90
SKU: SEN0162
  • $5.80 2+ items
  • $5.60 5+ items
  • $5.30 10+ items
UV Sensor detects UV radiation (200-370nm) with fast response and linear analog output, ideal for UV monitoring in various applications. Small and easy to install.
This UV Sensor with GUVA-S12SD chip is suitable for detecting the UV raditation in sunlight. It can be used in UV Index Monitoring, DIY project, UV-A Lamp Monitoring, Plants growing Environmental monitoring...etc.
It can detect the UV wavelength of 200-370nm, fast response, linear analog voltage signal output. Small size, easy for installing. With the diagram of the world health organization UV index grading standards, you can know the UV index from the sensor directly.
Датчик ультрафиолетового излучения, модуль SEN0162 от DFRobot
  • UV-A Lamp Monitoring
  • UV Index Monitoring
  • DIY UV electronic project,etc
  • UV Sensor x1
  • Analog Cable x1
Guillaume.Boucher Jun 26, 2024
Easy to setup and use!
