Aluminum Case For Raspberry Pi B+/2B/3B
$17.90
SKU: FIT0417
Stylish aluminum case for Raspberry Pi models B+/2B/3B, featuring durability, high precision, and easy GPIO cable use. Size: 103x67x41mm, Weight: 100g.
Give your Pi a stylish, solid and sweet home! This elegantly crafted Raspberry Pi model B+/Pi 2 model B case is designed for the perfect combination of durability, affordability, and strength. It comes with high quality aluminium casing, CNC metal processing, high-precision dimensions and anodic oxidation processing. Its rigid design also makes it a work of art. The grooved bottom design makes it easy for you to use GPIO cables.
Fully compatible with Raspberry Pi 3 model BRaspberry Pi 2 model B and Raspberry Pi model B+
  • Size: 103x67x41mm (4.06x2.64x1.61")
  • Weight: 100g
  • Aluminum Case for Raspberry Pi B+/2B/3B    x1
