Optical Fingerprint Sensor (UART, 1000 Fingerprints)
$34.90
SKU: SEN0188
An Arduino-compatible fingerprint module that stores 1000 prints, supports various devices, and offers high sensitivity recognition for security applications.
Purchase this product and earn 349 reward points, which are tied to VIP membership program. Learn More >
This is an Arduino compatible fingerprint module. With the high speed DSP processor, it could also work with other serial device, like MSP430, 51, AVR, PIC, STM32, ARM and FPGA device. This fingerprint module could work alone without any principal computer or any PC software. It could store 1000 fingerprints. Support fingerprint entry, intelligent image processing, fingerprint comparison and fingerprint search mode. It also has a high sensitivity to both wet and dry fingerprint recognition.
This module could be widely used in security field, such as license management .etc. It can also be used to replace the IC card, password, hardware switch in your application.
  • Power supply: DC 3.8V-7.0V
  • Operating current: 65mA (Typical)
  • Interface: UART (TTL logical level)
  • Baud rate: (9600*N)bps, N=1~12(default N=6, 57600bps)
  • Image acquisition time: <1S
  • Storage capacity: 1000
  • FAR: <0.001%
  • FRR: <1.0%
  • Average searching time: <1s (1:500, average)
  • Matching Mode: comparison mode (1:1) and search mode (1:N)
  • Character file: 256 bytes
  • Template file: 512 bytes
  • Security level: 5(1,2,3,4,5(highest))
  • Working environment: Temp: -20°C - +60; RH: 40%-85%
  • Storage environment: Temp: -40°C - +85°C; RH: <85%
  • Touch area dimension: 14.5*19.4 mm (0.57*0.76")
  • Outline dimension: 54*20*20.5 mm (2.13*0.79*0.81")
  • Fingerprint sensor x1
IoT | Telegram Fingerprint Door Lock and Surveillance Camera w/ Night Vision
Projects IoT | Telegram Fingerprint Door Lock and Surveillance Camera w/ Night Vision
Kutluhan Aktar
Nov 17, 2022
KOUBELAN RICHARD.AKPAGNI Nov 08, 2025
Reliable and easy-to-use optical fingerprint sensor! I tested it with an ESP32 and it performed flawlessly. The UART interface is simple to integrate, and enrolling or verifying fingerprints is very fast. It can store up to 1000 templates, making it perfect for access-control or attendance systems. The sensor’s recognition accuracy is excellent, even with slightly wet or dusty fingers. Build quality is solid, and the examples provided by DFRobot make setup quick and straightforward. Highly recommended for any IoT or embedded security project.
