Arduino 9 Axes Motion Shield
$29.00
SKU: DFR0407
The 9 Axes Motion Shield uses a BNO055 sensor for 3D acceleration, yaw, and magnetic field data, with features like sensor fusion signals and interrupt detection.
Arduino 9 Axes Motion Shield integrates the Bosch Sensortec BNO055 absolute orientation sensor into a convenient expansion board for Arduino platforms. This motion tracking shield combines a triaxial accelerometer, triaxial gyroscope, and triaxial geomagnetic sensor with an onboard 32‑bit microcontroller running BSX3.0 fusion algorithms. The embedded processing engine directly outputs stable orientation and motion data without requiring complex external calculations. Such integrated motion sensing hardware simplifies development of robotics, navigation, and interactive electronics projects that require accurate real‑time spatial awareness.
Integrated 9‑Axis Motion Sensing with Sensor Fusion
This orientation sensing shield incorporates the BNO055 System‑in‑Package architecture, combining a 14‑bit triaxial accelerometer, 16‑bit triaxial gyroscope with ±2000°/s measurement range, and a triaxial geomagnetic sensor. A dedicated 32‑bit microcontroller executes Bosch BSX3.0 FusionLib algorithms directly on the board. The integrated processing core fuses acceleration, rotational velocity, and magnetic field data to produce stable orientation outputs while reducing computational load on the main microcontroller.
Direct Orientation and Motion Data Outputs
The motion sensing board provides multiple high‑level motion outputs that simplify orientation tracking in embedded applications. Available data streams include quaternion orientation, Euler angles, rotation vectors, linear acceleration, and gravity vectors. Access to processed sensor fusion signals enables rapid implementation of motion‑aware systems such as robotic stabilization, gesture detection interfaces, or navigation systems without implementing complex mathematical filtering on the host controller.
Intelligent Motion Interrupt Detection
An onboard interrupt engine enables automated detection of specific motion events. Configurable triggers include slow or no‑motion recognition, any‑motion or slope detection, and high‑g event monitoring. Such built‑in motion event detection allows embedded systems to react quickly to physical movement while minimizing processor overhead and power consumption, making the orientation sensing shield suitable for wearable electronics, robotics monitoring systems, and responsive interactive devices.
The 9‑axis motion sensing expansion board is also compatible with the TinkerKit ecosystem, enabling rapid prototyping by connecting modular sensors and actuators directly to the board. Combined orientation sensing, motion detection capabilities, and plug‑and‑play expansion support make this motion tracking shield suitable for robotics control systems, motion analysis projects, interactive installations, and STEM Education experiments involving spatial awareness and motion tracking.
  • BNO055 absolute orientation sensor with integrated sensor fusion
  • Triaxial 14‑bit accelerometer
  • Triaxial 16‑bit gyroscope with ±2000°/s range
  • Triaxial geomagnetic sensor
  • Built‑in 32‑bit microcontroller running BSX3.0 FusionLib
  • Outputs quaternion, Euler angles, rotation vector, linear acceleration, and gravity vector
  • Integrated intelligent interrupt engine
  • Supports slow/no‑motion, any‑motion, and high‑g detection
  • TinkerKit compatible for rapid modular prototyping
  • Robotics orientation and motion tracking
  • Gesture recognition systems
  • Drone and robot stabilization
  • Navigation and positioning projects
  • Wearable motion monitoring devices
  • Interactive electronics and gaming controllers
  • STEM Education motion sensing experiments
  • Operating Voltage: 5V and 3.3V
  • Power Consumption: 50mW
  • Weight: 32g
  • Arduino 9 Axes Motion Shield x1
