ECell: Breadboard-Plugin Components Pack (36 PCS)
$19.90
SKU: KIT0098
A components pack for breadboard experiments, including resistors, capacitors, LEDs, and transistors, with gold-plated pins for easy, reliable use.
Breadboard-Plugin Components Pack is a new kit designed for breadboard experiment. It provides many kinds of components, such as resistors, capacitors, diodes, transistor .etc. The module pins are using gold-plating technology, solid and durable. It could be plugged on the breadboard directly. easy, reliable and reusable.
This innovative approach will solve the following issues caused by using DIP type of components:
  • Hard to read the value (Resistor color codes)
  • Severe deformations of the pin after used, non-reusable, not environment-friendly
  • The pin diameter is too thin or too thick, poor match with the breadboard hole
  • Confused the order of transistor “e”, “b”, “c” pins
  • Usage problem: Most of sensors and actuators require 3 interfaces: Signal/VCC/GND, you have to use the jumper wire for the connection, messy and unreliable.
Breadboard-Plugin is designed by Maker LeoYan, produced and sold by DFRobot.
Note: Breadboard is not included in the pack.
  • Easy to Recognize : Resistance value, capacitance values, positive/negative polaron and pin functions are marked clearly.
  • Easy to Learn : The circuit symbol is clearly visible, directly match the circuit diagram
  • Easy to Use : Direct-plug pin
  • Easy to Plug/unplug : The 0.64mm diametral pin matches the breadboard hole perfectly
  • High-Reliability : ENIG technology, the circuit connection is reliable and durable
  • Environment-Friendly : Reusable and Environment-friendly
  • Resistor: 220R,1K,4.7K,10K
  • Capacitor: 22pF@50V,100nF(0.1uF)@50V,47uF@10V
  • LED: Red, Yellow, Blue, Green
  • Diode: If=1A, Vfm=0.7V, Vr=40V
  • Transistor-NPN: Vceo=45V, Ic=500mA, hFE=400
  • Transistor-PNP: Vceo=-45V, Ic=-500mA, hFE=400
  • Resistor 220R x4
  • Resistor 1K x4
  • Resistor 4.7K x4
  • Resistor 10K x4
  • Capacitor 22pF x2
  • Capacitor 100nF x2
  • Capacitor 47uF x2
  • LED--R x2
  • LED--Y x2
  • LED--B x2
  • LED--G x2
  • Diode x4
  • NPN transistor x2
  • PNP transistor x2
  • Breadboard PluginConnector x2
Only 19 Left
